DOWN on the right side (passenger) side towards the bottom ahead of the right axle housing is a tear drop shaped cover with a cap held on by to bolts with wing nut style heads . Place a bucket under it unloosen the two wing nut bolts and twist the cap and wiggle it off . You should only loose about a gallon or so UNLESS someone has over filled the rear end then ya may loose more . I do believe you need and owners manual as you need to learn about your tractor .
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
