You can usually purchase a tractor with a loader for less cost than buying them seperately. Most loader tractors already have fluid ballast in the rear tires and/or extra wheel weights. Often loader tractors can be purchased with tire chains and a heat houser if you ask.
An H and a C are close to the same horsepower, but a bare H would have close to 1000 pounds more weight than a bare C, more gear selections and a longer wheel base, all will help a lot with a loader. An H with a loader should be able to push and lift nearly twice as much as a C with a loader. Similar to comparing a John Deere B to an MT or a J.I. Case SC to a VAC.
Farmall H tractors are useful, plentiful and inexpensive. If you can find a Farmall SH, SM, 300, 350, 400, 450, Oliver 77, 88, or Case 400 for not much more money I would jump at it though. The live hydraulics and faster gears will be more useful.
A loader makes a tractor longer, clumsier and steer harder, especially with a wide snow bucket. If you don't want to have two tractors, consider getting a loader that is easy to remove and install so you can easily drop the loader when you don't want it. A Deere #45 loader is one that is easy to remove, others loaders may be similar.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
