Re: Re: Locked up 'M' farmall
Posted by justin on December 11, 2000 at 10:53:23 from (209.18.233.187):
In Reply to: Re: Locked up 'M' farmall posted by Justin on December 11, 2000 at 10:36:52:
the tractor cannot be locked between 4th and 5th gear, because both "gears" are carried on the same gear. Just take the shift lever out, and make sure all forks are aligned, and check for wear on the lever. if everything looks okay, and the problem continues, you will probably have to remove the trans deck and check everything out. There are many things that could have caused this problem, so a little time may be needed..
Post A Followup
: Re: Re: Re: Locked up 'M' farmall
