Re: T/A on 450
Posted by D Slater on December 16, 2013 at 12:21:44 from (184.14.199.118):
In Reply to: T/A on 450 posted by Hugh McKinney on December 16, 2013 at 11:04:44:
If the link from the main clutch shaft to the T/A clutch shaft is off or not moving the T/A shaft. Before pulling the lever I would remove the cover over the T/A clutch and check condition of the release bearing and T/A clutch fingers and springs. Also the T/A clutch may be stuck if the link between shafts wasn't operating. Also if the link wasn't working and you don't have a hard time shifting the transmission out of gear at times. The T/A probably doesn't work.
Forgot to say for IH linkage adjusting specs you need to use the one for a 450.
This post was edited by D Slater at 12:24:27 12/16/13.
