Re: '42 H Just Won't Start
Posted by Tom Fleming on December 16, 2013 at 16:09:51 from (173.233.18.197):
In Reply to: '42 H Just Won't Start posted by Farmer Matt on December 16, 2013 at 07:30:46:
ok, some good advice has already been posted here. An engine needs 4 things to run: fuel, air, spark, compression
The only thing I am going to do is put it in order like a check list:
1.) Make sure valves are set at correct, COLD lash.
2.) Set timing manually. As already indicated, get #1 TDC for the compression stroke. As indicated, install distributor firing at #1.
3.) Make sure plugs and points are properly gapped.
4.) Wires should be copper core, with bright, clean connections. Firing order 1,3,4,2, going clockwise from #1 post which is at approximately 2 o'clock on the cap.
5.) Turn on fuel, and make sure carb is getting plenty of fuel flow.
6.) Iidle air adjustment should be closed tight, then out 1 1/2 turns. Main jet, same, bottom out then at least 2 to 3 turns out.
7.) Air cleaner should be clear and clean. Fresh oil.
8.) Open and consume beverage of your choice, review and recheck previous 7 steps.
7.) start it. Consume 2nd beverage whiling enjoying the sound of your Grandpa's running tractor.
