Re: 1586 throttle lever stuck
Posted by Hugh McKinney on December 16, 2013 at 19:55:22 from (75.104.206.23):
In Reply to: 1586 throttle lever stuck posted by Dave H (MI) on December 16, 2013 at 17:05:45:
The easiest way to find it is to start at the injection pump, on the left side, just above the frame rail, and work your way backwards til you come to the lowest point, which is likely the location of the ice. Get you a good propane torch if you don't have electricity where it is, but take it slow! Good luck, Hugh
