Re: 756 starter problem only when cold
Posted by Owen Aaland on December 17, 2013 at 02:59:01 from (216.47.34.47):
In Reply to: 756 starter problem only when cold posted by cdb on December 14, 2013 at 09:08:22:
It is too late for it to "suddenly" stop working. It is already giving you its warning that it is failing.
The information I posted earlier for diesel engine starters mostly applies to the gas starters also. The drive gear is still a ten tooth gear but it has a smaller OD. The part number is 1851427. If it has been replaced before you may find a nine tooth drive gear (part number 1939109) since that drive was used in earlier gas starters. Use the ten tooth gear for replacement. It will last longer.
