Re: HARD STARRTING 656
Posted by Ace Schrunk on December 11, 2000 at 13:54:00 from (207.232.79.81):
In Reply to: HARD STARRTING 656 posted by charles on December 11, 2000 at 04:18:42:
The only good way to check the glow plugs is to take thwm out and look at them to see there are not burnt off and check to see that they get red hot then put them back. you can use starting fluid
just make sure that engine is turnning over be for you cive it the fluid.
Post A Followup
: Re: Re: HARD STARRTING 656
