Re: M bypass - what info is correct?
Posted by Bob M on December 17, 2013 at 19:49:02 from (65.110.157.186):
In Reply to: Re: M bypass - what info is correct? posted by notjustair on December 17, 2013 at 19:19:22:
Yes to both.
The crescent-shaped hole is the one you need to fill/drill. And the t'stat housing is cast iron.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
