I don't know, but my H was much easier to start in the winter, even by hand. Once it fired I knew that I could play with the choke and it would run. When the temperature is below 20 or so my 300 starts right up and runs on all cylinders for about 5 seconds and then dies, and I can't get it to fire again no matter what I do. It has gas in the carburetor but it is not getting to the plugs since they seem to be dry when I check them. I have checked for manifold leaks and checked for spark and have not found anything. I have not checked the compression but I suppose that could be the problem. One thing that is very different from the H is that my 300 has the hydraulic pump and the IPTO connected directly to the engine, where if I blocked the clutch on the H it would isolate the engine from all loads. I bought a 600W lower hose heater in town yesterday and am planning to put it in today. I also got a set of new plugs since my old ones are not as clean as they should be. Zach
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
