Not hard, if the tractor was previouly starting easy before the starter broke. Check and double check to make sure the tractor is not in gear. Good idea to set the foot brakes so the tractor does not roll when being cranked. Choke the same way as if using the starter. My C normally takes one crank at 3/4 choke and will fire on the next crank with the choke at less than 1/2. I set the trottle between 1/3 and 1/2. Enough for the cold motor to continue running but not so much the motor races at full RPM. Hope this helps.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
