Not to repeat but if it was starting good before starter broke, it will crank. Otherwise you will need to check flow of gas to the carb, pull a plug to see if it is wet after cranking a few turns, this will tell you gas is getting to the cyclinders. No gas could be clogged gas line or clogged carb. If still no go, check for spark at a plug. It would not hurt to clean and check plug gaps. Should be a blue streak about 1/4 inch. If not check the condition of points. My last no start was solved by changing the condensor.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
