Issue one: The new coil is just a 14 volt capable set of windings rated for 12volt operation, it has no internal resistor. There is no reason to use an additional resistor, it will cause poor spark for sure. Issue two resetting the points to .020 could have helped if the shaft was worn, or the timing retarded some. If it didn"t help, the issue may be fuel supply to the carb. Open the load screw on the front of the lower edge one turn at a time to see if it gets better. If not put it back where it was. If a fuel line filter has been put on it, take it off and use a hose where it was located. Make sure there is full 1/8" stream of fuel at the carb (there is a strainer at the fitting!) Keep us informed. Jim
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati
... [Read Article]
Latest Ad:
[More Ads]
