Re: Please help farmall m coil trouble and picking corn
Posted by Russ600 on December 18, 2013 at 17:08:08 from (162.212.68.75):
In Reply to: Please help farmall m coil trouble and picking corn posted by Buckshot farm on December 18, 2013 at 13:52:17:
Hi.
Resistors should be available at any parts store, they are installed on the wire from the power source to the coil. They can be mounted on the frame or anywhere it is convient. Are your new points showing signs of burning or is your coil getting hot? If they are it is an indication that a resistor is required, if not you may not need one. Missing under load could also be some crud in the hign speed side of the carb., or maybe you got a shot of bad gas. Hope you get it running soon.
Cheers
Russ
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
