Re: Selective Lift Control and 2 Implements
Posted by DeltaRed on December 18, 2013 at 19:12:32 from (65.100.146.8):
In Reply to: Selective Lift Control and 2 Implements posted by chemrhetoric on December 18, 2013 at 17:56:27:
If you're asking the question I think you are
aasking,Yes you can use the "selective control
valve".One side for the loader,one side for the 3
point.The center 'slot' would run both hitch and loader at once..
