Hi, Tractor should start quite easily with the hand crank. Set brakes and double check that the transmission is in "N". When facing the tractor turn engine over with the crank until your at about"7:00 as on the clock" quick pull upwards and usually this is all that's required for starting. Don't lock your thumb around the crank handle. As with anything you attempt to do around old machinery , alway's think of SAFETY. I suppose there could be a kick back, if your hand is placed properly on the crank handle, the most it could do would pull back from your hand. Many times the advice received from some of the members that post on this board is the danger for hand cranking, it can happen, although it usually doesn't. I have a Super A and most times just use the hand crank, although I have had all my INT. starters rebuilt. Cheers, Murray
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
