Re: valve stuck
Posted by gene bender on December 19, 2013 at 18:44:56 from (207.177.56.213):
In Reply to: valve stuck posted by ken house on December 19, 2013 at 16:35:10:
That engine uyou can remove the side pannel and then see the stem. See if you cant get the valve to move shouldnt realy be stuck that hard using anything spraying on it before trying to move it.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
