Re: valve stuck
Posted by rustred on December 19, 2013 at 18:53:44 from (74.214.152.80):
In Reply to: valve stuck posted by ken house on December 19, 2013 at 16:35:10:
sure is a heck of a lot easier than getting a stuck piston to move. lots of times you can go in from the spark plug hole and use a screwdriver or make something to push on the head of valve. and spray lube from the inside also. I have unstuck valves without even taking the valve cover off.
Today's Featured Article - Welding Basics - by Curtis Von Fange. One of the most useful skills that an owner of older equipment can have is the knowledge and ability to weld. It seems like the older equipment can do a job, albeit slowly compared to newer stuff, but it tends to break more often. Many of the breakdowns are related to the implements that are being used: the disc, wagon or bushog are among them. Knowing how to fix stress cracks, reinforce weak joints by welding on steel support plates, or cutting and shaping parts and adapters out of raw stee ... [Read Article]
