Posted by old on December 19, 2013 at 18:56:47 from (209.86.226.58):
In Reply to: valve stuck posted by ken house on December 19, 2013 at 16:35:10:
Well if you can get it so the cylinder can be filled with ATF and let sit a few days that works well on many but you have to cap off the exhaust or intake so that you can keep the ATF on the whole thing. Then if you can through the spark plug hole tap it down when you are sure it should be closing. I have had good luck doing that. But also had one that doing that did not help at all
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
