Posted by TedinNE on December 19, 2013 at 20:05:45 from (63.172.255.207):
In Reply to: Re: 450 TA Follow-up posted by Hugh McKinney on December 19, 2013 at 17:45:22:
Yes front split at clutch housing. You can then work through the top cover on the TA housing. Also remove the clutch shaft out the front. You can then remove the TA clutch assy. The nut that retains the clutch carrier has a lock tab washer that is supposed keep the nut from coming loose. Will be good to inspect the condition of the TA clutch & main clutch while tractor is split. The 2 seals for the IPTO shaft & front seal for the TA planetary carrier should also be replaced.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
