Re: Farmall A from tires
Posted by T.J. on December 11, 2000 at 18:56:14 from (209.240.221.110):
In Reply to: Farmall A from tires posted by 'Bandit' on December 11, 2000 at 15:21:42:
I`m not sure about A`s but on our M there are two blocks about 1/4 inch thick 2 inches long and as wide as center rib on the rim, welded on so there is one on each side of the wedge so it will not slip either way It was welded on by drilling a hole in just the block, and welded through the hole like a big spot weld.its factory I`m not sure if its IHC but it works Hope this helps Tom
Post A Followup
: Re: Re: Farmall A from tires
