Re: Farmall H Clutch stuck
Posted by FBH44 on December 20, 2013 at 03:00:54 from (64.85.215.135):
In Reply to: Farmall H Clutch stuck posted by Farmallman2013 on December 19, 2013 at 22:46:17:
You can check to see if the pressure plate fingers are adjusted correctly, just by rotating the plate three times, and from underneath checking the gap. Mine works best at a 3/16" gap. Easy to check, easy to re-adjust.
