Re: Farmall H Clutch stuck
Posted by tractorsam on December 20, 2013 at 03:15:03 from (71.7.253.88):
In Reply to: Farmall H Clutch stuck posted by Farmallman2013 on December 19, 2013 at 22:46:17:
Sorry if this sounds very basic but the friction disc should only usually be installed in a specific orientation. IE one particular side must be against the flywheel, could you have it in backwards? Good luck, Sam
