Posted by mkirsch on December 20, 2013 at 05:01:38 from (65.199.189.6):
In Reply to: 450 TA Follow-up posted by Hugh McKinney on December 19, 2013 at 07:22:34:
Is the tractor hard to shift?
With a good TA, the tractor should be hard to shift if there is something wrong with the TA clutch that's keeping it from releasing.
If the tractor shifts easily that means one of two things:
1. The TA is no good. The low side is out.
2. The linkage to the TA lever is out of adjustment, but the TA is otherwise OK.
Get off the tractor and find where the linkage from the TA lever goes to. Pull the TA lever. Does the arm that the TA linkage is connected to move? Push the clutch pedal down. The same arm should move the same amount.
If the TA lever doesn't move that arm, or doesn't move that arm as much as the clutch pedal does, it's out of adjustment.
All the mechanical TAs operate the same way, from the super MTA up to the 560.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
