Re: Fenders for Regular and F-30
Posted by rusticredacres on December 20, 2013 at 05:26:58 from (38.86.67.219):
In Reply to: Fenders for Regular and F-30 posted by bobinmi. on December 18, 2013 at 09:36:36:
Bob, No I do not have any F30 fenders. There are several part #s for the Regular starting with 15255DX and 15256DX Wisconsin only serial# 701 and below. These had a special mounting cast bracket extra part to mount these because of drop housing inner plate was different. Then 15255DAX and 15256DAX serial# 701-1150 slight change in mounting braces ? Then 15255DBX and 15256DBX serial# 1151-27670 maybe slight changes again. Then 15551DX and 15552DX serial 27671 and up. All the above part #s are the three brace fenders. Some slight differences but basically the same version. These were all the short side panel style. Then part# 23063DX and 23064DX were used as a field change which is the same fender as the early F20 short side panel for steel wheel or 28 inch or smaller rubber tire application. Quite a variety of fenders and makes me glad I was not the parts man back in the day.
