Re: batteries
Posted by Russ from MN on December 20, 2013 at 08:51:26 from (68.235.89.3):
In Reply to: batteries posted by butch49 on December 19, 2013 at 20:20:28:
A common reply to you question is, The biggest that will fit in the box! You didn't say 6 or 12 volt, or does it have a heater? And the oil? If you are going to start it out in the cold you might want lighter oil than 10W40. Lots of good advice from others.
