Re: Farmall H Clutch stuck
Posted by old on December 20, 2013 at 09:28:06 from (209.86.226.27):
In Reply to: Re: Farmall H Clutch stuck posted by Farmallman2013 on December 20, 2013 at 09:23:32:
Sounds like the clutch is not releasing as it should so maybe you need to do some adjustments. And if you used the old pressure plate the arms maybe bent a tad bit so with the new disk it is not releasing as it should be
