Re: valve stuck
Posted by Duner Wi on December 20, 2013 at 09:35:59 from (216.226.80.242):
In Reply to: valve stuck posted by ken house on December 19, 2013 at 16:35:10:
I have had good luck with stuck valves in flat heads. I made a "L" shaped tool to get to valve and lots of light tapping and I prefer Marvel Mystery oil but you could save $50.00 and use ATF with probably the same results. After you get it free I would use the same lube in the gas for awhile.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
