I owned one of these but only kept it a few months. Not easy to work on. Weighs about 6000 lbs. blade probably another 1500 lbs. Total less than 8000 lbs. Easy to drive if clutches and brakes are all working. If it won't move, brakes may be stuck. This thing shares many parts with the 340 wheel tractor. Same engine, gears and so on. If it rolls when tranny in neutral you should be able to tow it easily. Has 5 speed transmission and steers with the hand levers. Pull lever back and clutch on that side releases. Pull harder and brake is applied. Mine had leaky pinion seals that allowed oil to leak onto the dry disk brakes that are located between the transmission and the final drives. One side brake wood not hold so you could only turn to the right. Brake repair requires removing the track and the final drive. A heavy job. Good little machine if you can get it going. It's encouraging that it runs. Good luck!!
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
