Re: Just PU a TD 340 Dozer new to posts
Posted by Janicholson on December 20, 2013 at 16:00:48 from (199.17.6.37):
In Reply to: Just PU a TD 340 Dozer new to posts posted by PecosAllis on December 20, 2013 at 08:09:42:
I like it! If it is and has been below freezing, it might have ice in the trans, and finals.. If so it will not move (nor should it be moved) until unfrozen. Clutches can and do sieze, and so do brakes. If the brakes are frozen, they will need to be unstuck before moving it. (or removed) Jim
