Re: Farmall H Clutch stuck
Posted by Janicholson on December 20, 2013 at 16:27:25 from (199.17.6.37):
In Reply to: Farmall H Clutch stuck posted by Farmallman2013 on December 19, 2013 at 22:46:17:
If the PP you used is worn in the pivots and fingers ift can drag. if the new disk gets a little bent it can drag. If the clutch shaft is worn the splines will cause the new clutch to drag as it finds its seat on the splines.. If the splines are it, the new disk can have a little taken off the splines so it can be where the old one ran. Jim
