Re: F20 Hydraulics
Posted by oldiron29 on December 20, 2013 at 17:26:49 from (74.88.13.13):
In Reply to: F20 Hydraulics posted by mschwartz on December 20, 2013 at 15:59:21:
Mike, When the cap is removed fromt he lower shaft There is a large slotted type groove that will mate with the shaft drive in the pump. I can't remember if I bolted the adapter plate to the pump before I mounted it or mounted the plate first? Bolts will only work one way. you will see how it goes when you have it in front of you. oldiron29
