Re: batteries
Posted by Janicholson on December 20, 2013 at 20:25:43 from (74.60.94.18):
In Reply to: Re: batteries posted by rustred on December 20, 2013 at 17:57:18:
Here is one of several. Trojan Brand AGM
Not cheap but what is. If starting is important, The price might be OK. Just ideas. A block heater and a oil p[an heater are sometimes needed. In Montana at 45 degrees below, power steering fluid is solid! Jim
Cap Minutes @ 25amps 383
CCA @ 0 f degress 1100
CCA @ 32 f degress 1400
AH @ 5 HR Rate 154
AH @ 20 HR Rate 200
Length 10.25" Width 7.125" Height 10.75"
Weight 65 lbs
Battery terminal AP & Stud
