ih 1086 fuel gauge wiring
Posted by mh mo, on December 22, 2013 at 06:46:47 from (98.20.113.37):
need help with wiring my fuel gauge ,need a drawling that is easy to understand to wire my fuel gauge to my sending unite on main tank to sending unite on aux.tank and back ??? all the wiring has been removed from tanks by a previous owner not sure why. and how do you check your sending unites.even if you can tell me how to wire from point a to b with out drawling will help thanks for your time
