Re: conventional points or electronic?
Posted by TheDurk on December 22, 2013 at 11:03:09 from (174.44.3.165):
In Reply to: conventional points or electronic? posted by muleboss on December 22, 2013 at 10:25:48:
I did that when I first installed it and I had no idea how good it would be. You think I should throw the points out now that the electronic is seven years old? I assume it will die eventually.
