Posted by fixerupper on December 22, 2013 at 16:55:21 from (100.42.83.15):
In Reply to: 1066 Clutch posted by Curt 650 on December 22, 2013 at 14:02:29:
A new clutch put in my 1086 by a dealer this fall was in the $2500 range. Flywheel was turned, new pressure plate, PTO stub shaft replaced, new rear seal and clutch booster seal set installed. Done and back out the door in just a little over a day. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
