If completely removing the engine for disassembly and you have a hoist or something to lift the heavy parts? Block up behind engine, block rear tires. Use a lifting device or plenty of help and remove the front bolsters and radiator as one assembly when removing the frame rails. Sometimes helps to leave one frame rail in place when removing the bolster so that the front bolts to bolster are removed last. Two 1/2 inch bolts will be left supporting the engine, To remove one of the bolts needs the starter removed. Before that though if desired a lot of engine parts can be removed along with the front engine cover while its hanging on the tractor. Put a couple of bolts in the holes where the frame rails were removed if it makes you more comfortable while working. After removing all engine parts that you want off at the time. Support engine, remove bolts, engine and then the flywheel and any other parts.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
