MD Injector Prep?
Posted by hattrick on December 23, 2013 at 14:36:01 from (216.57.221.66):
I just got my injectors back from Central Fuel Injection for my MD. Amazingly Quick Service by the way. The injectors came back with new O-rings and a set of metal gaskets for the bottom of the injectors. There is a little carbon, corrosion and slight surface rust in the injector holes. Should I just use a little diesel and emery to clean them up? ALso should I use vaseline on the o-rings or some other lubricant before I slide them in?
