Re: 460 Farmall block questions
Posted by CharlieU on December 23, 2013 at 20:01:23 from (209.131.225.223):
In Reply to: 460 Farmall block questions posted by wcallispuller on December 23, 2013 at 19:17:16:
Were you able to find the serial number and engine size that is stamped into the block? The numbers were stamped into the flat machine surface behind the oil filter mounting base when the engine was used in a tractor. When the engine was in the combine the numbers were stamped on the vertical machine pad on the upper right front corner of the block above the governor and just below the cylinderhead.
