Re: Might recieve a 1066...
Posted by mkirsch on December 24, 2013 at 05:00:03 from (65.199.189.6):
In Reply to: Might recieve a 1066... posted by PretendFarmer on December 24, 2013 at 04:13:40:
In its present state, it's worth around 5 tons of scrap metal, plus the value of any weights or weight brackets it has on it, about $100 per pair of rear wheel weights and $100 per front suitcase weight and $100 for the front weight bracket.
IIRC it's about 5 tons of metal, so anywhere from $1000 - $1500 would be fair for just the derelict tractor, as-is, no questions asked. You just winch the tractor up on the trailer and go. Any tinkering you do to the tractor to prove anything works only increases its value.
If the exhaust is covered, the engine is probably loose though. Diesels don't seize up as readily as gassers because diesel fuel is basically just thin oil, and it coats the upper cylinder walls preventing major rust.
