"Say for instance, a tractor has an ignition resistor and I happen to put on one of those coils with the built in resistor...... Wonder how the silly thing would act?
I can tell you how it would act, VERY BADLY the spark would be weak as coil voltage and current is gonna be less then it was designed for.
On a 12 volt tractor using a 6 volt coil, the ballast drops the 12 volts from battery down to 6 so the 6 volt coil sees what it was designed for, 6 volts, and a good spark.
BUT if on a 12 volt tractor you keep the ballast BUT USE A 12 VOLT COIL the coil sees quite a bit less voltage and current then it was designed for so the spark IS WEAK.
Id say symptoms may be hard to start and poor performance.........
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
