Re: Farmall H steering gearbox, shaft removal?
Posted by Zachary Hoyt on December 25, 2013 at 12:36:28 from (184.8.251.166):
In Reply to: Farmall H steering gearbox, shaft removal? posted by John V. on December 25, 2013 at 12:03:38:
I have had that happen when I forgot to remove the woodruff key on the U joint end of the shaft. Just a thought.
Zach
