Re: MD won't stay running on gas
Posted by old on December 25, 2013 at 17:51:28 from (209.86.226.30):
In Reply to: MD won't stay running on gas posted by Aussie Ken on December 25, 2013 at 17:32:31:
Do not know the MD well but know to old TD-6 which works the same way. Sounds like the carb is running out of fuel. If the carb has a drain plug which I think it should have pull that plug and let the fuel flow for a few minutes. I'll almost bet the flow slows down so when it slows down the engine dies due to lack of fuel Moist likely a float set wrong or a sticking float needle
