Re: M is getting coolant in oil.
Posted by DeltaRed on December 26, 2013 at 11:41:16 from (67.40.59.83):
In Reply to: M is getting coolant in oil. posted by crl800 on December 26, 2013 at 09:01:07:
Pull the pan.If you have access to a radiator pressure tester,put a little pressure(5-7 lbs) in.Look for drips apearing.As was said,cardboard underneath to catch drips.Sometimes it takes overnight for them to appear.Before you pull the pan,start engine,run for a bit.Look in radiator when engine is running.Look for bubbles/foam.These are indicitive of a failed head gasket.
