Farmall H Steering Shaft
Posted by IAtractorKid on December 26, 2013 at 11:59:24 from (216.81.154.234):
Hey guys! Replaced the small oil seal and steering shaft bushing in the upper bolster, and now the steering shaft won"t fit! Someone has welded the shaft up for the bearing at the center support so I"m wondering if they didn"t weld up the other end to fit the worn bushing. Either way I"m hoping someone will know the ID of that bushing when pressed in the bolster or what the OD of the shaft should be so I can turn it down. Thank you!!!
