Re: M is getting coolant in oil.
Posted by oliverman1855 on December 26, 2013 at 15:49:01 from (174.124.78.33):
In Reply to: M is getting coolant in oil. posted by crl800 on December 26, 2013 at 09:01:07:
We had a couple m's in tech that had that problem. All were cracked heads. I would pull the head and have it pressure checked, sometimes if the head studs are not sealed right they will leak also.
