Re: Re: F806D hyd. leak
Posted by the tractor vet on December 12, 2000 at 18:43:17 from (216.196.12.238):
In Reply to: Re: F806D hyd. leak posted by Mudcat49 on December 12, 2000 at 16:44:45:
Mudcat is almost right, there are 3 o/ringes and you need to pull the PTO to remove the draft sencening arm .The biggest problem you might have is removing the pin that hold the three point arms to the bellcrank, some times they come right out and others i have spent hours just on one of them. I also remove the three point top link bracket so i can watch in side when removing the PTO and also to aligen the draft sensing arm.I have done three this year.
Post A Followup
: Re: Re: Re: F806D hyd. leak
