Re: Farmall H headlight switch
Posted by Janicholson on December 27, 2013 at 12:54:31 from (74.60.94.18):
In Reply to: Farmall H headlight switch posted by Bill Koenig on December 27, 2013 at 12:06:56:
The L is for low charge through a resistor on the switch (using the light switch as a combination charge rate control, and a light switch), lights off. H is for High Charge direct field to ground through the switch body and elect box, lights off. D is for Dim lights through a wire wound resistor on the switch, and high charge. B is for Bright lights, no resistor and high charge.
