Re: farmall c dies after a few seconds of running
Posted by old on December 27, 2013 at 16:56:31 from (209.86.226.54):
In Reply to: farmall c dies after a few seconds of running posted by farmallboy15 on December 27, 2013 at 16:28:23:
3 things to check.
#1 pull the carb drain plug and make sure you have a good steady flow of gas for a few minutes. Catch the gas to make sure it is not full of water or dirt.
#2 check for a good blue/white spark the moment it dies.
#3 with the air cleaner tube off when it starts to die put you hand over the air intake and see if you can keep it running and feel a good suction. It may in fact have a vacuum leak so as it heat up you loose air intake suction
