Up to about 1949 or 1950, on the H you could get two types of lighting systems. One was the "no battery" Bosch system, and the other was the Delco-Remy system. The Delco system used a generator, battery, the associated wiring, and two front lights with one rear.
Some time in '50, the H used the newer Delco system, but this one had full voltage and current regulation. The older system had a voltage cut-out and a third brush in the generator. The easiest way to tell the difference between the two systems, was by the light switch and the regulator. In the later system, the regulator was located on the rear fuel tank support, directly behind the steering post, and the light switch only had three positions.
The older Delco system had the "regulator" (this was the cut-out) mounted on the top of the generator. Both the old cut-out, and the newer regulator looked the same, but were electrically different. The switch on the older system had four positions as follows from extreme counter-clockwise to extreme clockwise: L(ow), H(igh), D(im), and B(right). A previous poster outlined those functions.
To double check the system you have, and verify the type, just look at the generator part number and check that with the parts book. If your tractor is a '48 or earlier, it is a pretty safe bet you have the older system.
A disclaimer here on identification: I have heard that a few of the early regulated systems had the regulator installed on the top of the generator as was done in the old system. In such a case, you definitely need to check the part number on the gen. to verify the type.
As a short cut, you can also remove the band on the back of the gen. and simply count the brushes inside. The new generators only had two brushes, while the older ones had three.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
